Posted by Owen Aaland on March 09, 2010 at 15:16:53 from (198.70.47.146):
In Reply to: 560 starter end play posted by IowaHarry on March 09, 2010 at 13:18:52:
I don't recall ever seeing a spec for the armature end play in the Delco manuals. The minimum clearance for the drive gear to stop collar is .020". The stop collar should not contact the drive end housing.
The end play is controlled by spacer washers on the commutator end and between the center bearing and the armature. I have seen the commutator end washers in some rebuilt units that have been replaced with non-hardened washers which bend in use allowing excessive end play. If there is excessive wear in the commutator end frame it is sometimes possible to add a second washer to compensate for the wear. When assembled the armature must not drag from lack of end play.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
