My answer will be a hybrid of the two below. It was very common for the As to be shipped with a pressed/stamped steel wheel on the left side and a cast wheel on the right. This in addition to the weight of the operator on the same side was generally enough to overcome any tendency of the offset design to tip to the left in normal and prudent operation on a sidehill or turn.
If you should have one with stamped wheels on both sides, a single wheel weight on the right side would have the same effect.
If you already have the conventional steel on the left and iron on the right, and are merely adding weight for traction, then adding weights on both sides would be appropriate.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
