Re: Bull pinion and brake shaft seals
Posted by TractormanNC on March 18, 2010 at 18:14:58 from (209.42.180.69):
In Reply to: Re: Bull pinion and brake shaft seals posted by Dave47M on March 18, 2010 at 18:04:03:
Search the archives, this has been described several times.
Here is the basic idea. Pull the PTO assembly. Remove the bolt and washer holding the bull gear to the axle. Remove the 4 bolts at the outside end of the axle housing, slide the axle out and let the bull gear drop out of the slot in the bearing cage. Then you can pull the cage.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
