Posted by Wardner on March 18, 2010 at 20:00:20 from (4.154.238.150):
In Reply to: Hydraulic question posted by Spotted Horse on March 17, 2010 at 22:58:21:
I would consider converting the transaxle into a reservoir. Replace the gear oil with Hy-Tran or equivalent. Place a strainer, check valve, and tee at the rear drain plug or a safer remote location with a suction hose. The check valve might not be necessary. It depends how good your pumps are at holding a prime.
Despite what Jim says about the PTO pump, the Prince pump will easily handle 1200 RPM. The same pump is used with 1000 RPM PTO. The mfg changes out the internal splines to suit 540 or 1000 PTO shafts. I can't think of any small hydraulic gear pump that can't run at 2000-2500.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
