Posted by mkirsch on March 19, 2010 at 05:39:06 from (64.80.108.55):
In Reply to: gas to diesel '706 posted by cmathas on March 18, 2010 at 18:01:10:
EVERYTHING between the front bolster and the bell housing is different from gas to diesel. Frame rails, front and rear engine plates...
Early 706 has a D282, late has the D310 "German" diesel.
Is the D301 the bored-out combine version of the D282, or did you mistype?
Converting is a lot of work and a lot of parts, even if you fudge a few things and do some fabrication. To do it "right" is even more parts.
We had a D360 American diesel out of a bus put in a gas 756 several years ago. The mechanic used the gas frame rails so the tractor is now 1" longer and the hood doesn't fit without extensions. He also used the gas radiator, and the outlet is on the wrong side. The mechanic's son TIG welded up a cross pipe for the radiator, so the extra inch of clearance up front came in REAL handy. Power steering lines had to be extended. It looks a bit cobbled up around the bell housing area but it all works and it's solid.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
