Not true. Especially with thermally-protected glow-plugs like Ford uses. Made by Beru and stuck into Motorcraft boxes.
Typical Powerstroke ZD-11 glow plugs is easily tested by feeding full voltage to it through an amp-meter. Pluges are wired in parallel and all get full system voltage.
Should draw 7.5 amps and when hooked to 12 volts, heats up to working temp in 7-9 seconds.
On the other hand, the plugs used in the IH B-275 and IH B-414 are only rated at 9/10ths of one volt and MUST be hooked in series and all five must be in the system. Four in the engine and one on the dash.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
