Posted by IH fan on March 20, 2010 at 18:40:39 from (70.250.251.113):
In Reply to: 240 steering gear posted by sd pete on March 18, 2010 at 21:59:19:
Sounds like the key is either missing or sheared off. Mine had been sheared off in the past and a new Woodwuff keyway milled in the shaft 180 out from the original. then it had also had sometime in the past had a steering arm from a 404 installed which would be in a bind when it reached either end of the stroke. I got the correct 240U arm with my new gears, bearings and bottom cover and it clears fine. That also made it easy to change out.... pull the worm shaft, jack up the front, block up the tractor, drop the front axle, drop the gear/shaft and re-install the new one. I had a buddy do it 'cause he had the jacks, etc. and it took him 3 hours to do that and install new brake discs.
This post was edited by IH fan at 07:36:02 03/21/10.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
