Re: 200 single front wheel - loading bearings
Posted by bodid1998 on March 23, 2010 at 22:08:03 from (63.245.245.5):
In Reply to: 200 single front wheel - loading bearings posted by carlsandberg on March 23, 2010 at 17:39:16:
deltared said: (quoted from post at 02:00:37 03/24/10) you must have a newer/different than mine.mine did not have bearings when i took it apart to chsnge the tire.
Delta is yours the solid cast iron wheel or the pressed steel one? Mine was the cast solid wheel with a cast bearing carrier that bolts to wheel center.
Dustin Il
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
