Posted by JimB2 on March 25, 2010 at 19:39:19 from (208.94.30.106):
In Reply to: Hydro 83 project posted by downeast maine on March 25, 2010 at 16:08:16:
Hi DE, the Hydro 84 is the same tractor as 784 except for drive train. It has a German D-246 Diesel engine. Re electrical, hopefully it has Delco not Lucas electrical system, there are a couple of connectors that give problems, one is under rear of seat and there is a ground lug that connects to seat platform that supplies ground to several of the circuits. Some tractors also have another connector under the battery box. Re Brakes, yes require bleeding, check archives for 674,684,784,584 brake bleeding method. Re PTO, PTO lever linkage will be siezed up, use your favourite penetrating oil and lube everything. Under the left foot rest will be the MCV valve and hydraulic filter. The PTO actuator is under the rubber boot on top right of MCV. You may have to pry boot up and squirt penetrating oil in actuator under the boot.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
