billde said: (quoted from post at 06:02:37 03/27/10)
sflem849 said: (quoted from post at 17:49:58 03/26/10)
MeanGene1 said: (quoted from post at 08:10:25 03/26/10) Man, if I only had the stacks of weights from the old dealership... IIRC, the smaller weights were considered standard size, and nominal 73 lbs, and the larger ones were optional size at nominal 102 lbs. Remember as a kid, you'd say "I can put those on"- then once you could, it became your permanent job LOL. Then gramps said, set 'er up for plowing, I'll be back in a while- which meant blowing the wheels out from 60" to 84" centers. Me at 12, and the old 8N with a Wagner loader, the little IH clamp bolt wrench & 4' of pipe. Actually, the rears were easier than the fronts
Same year I started putting on the 4-row cultivators (2) on by myself- the ones that bolted to the weight bracket holes and then swung in to the sides. After moving the wheels back in to 60" of course
What size plow were you running at 60"? I take it that is from center to outside of tread?
You can't plow at 60", he is plowing at 84", measurement is center of tire to center of tire. I only moved the right tire cause a dual went on the left.
I see that now. My mistake. What plow do you run at 84"? My tires are at 90" ish and they run my 3-14 pretty well.
That brings about another question. You were cultivating 30" rows back then!?! Most guys that farmed with Ms up here were still on wide rows.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
