Farmall Tractors Discussion Board
Re: Re: Re: Re: Farmall M - 12 V conversion
Posted by Dexter on December 31, 1998 at 14:43:23:
In Reply to: Re: Re: Re: Farmall M - 12 V conversion posted by Bob seND on December 22, 1998 at 19:39:29:
I have a 400w with a gas engine. During the winter, where I live, the temperature can drop to minus 45 degrees celcius (about minus 50 degrees farenheit). I installed a circulating water heater by running a line from the bottom drain of the radiator to a side port on the engine block (the inline heater is attached in between. I have no trouble starting the engine under such extremes if it is plugged in (getting the hydraulics to cooperate is another story!).
I have some problems with my conversion to a twelve volt system. I changed the coil to a 12 volt, got a 12 volt generator, put in a 12 volt voltage regulator, but after a while of using it the tractor began to run progressively worse. It would miss and backfire when I opened the throttle or had it working under load. I could operate it fairly well at low idle. I replaced the plugs, put in a new rotor, new distributor cap, and new plug and coil wires. I checked the gap in the points and gave it a try. Same problem. I disconnected the wires to the generator... end of problem. What's wrong and what can I do to remedy the situation. A friend suggested replacing the generator with a Delco alternator as it has a built in regulator. Has anyone else done the same with good success?
Post a Followup
: Re: Re: Re: Re: Re: Farmall M - 12 V conversion
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
