If you tried cranking the tractor and it didn't start could explain the gas leaking from the carb - they will do that, especially if you use much choke. As for the belts you don't need a belt on anything to start the tractor - only to keep it running for very long. You have to remove the fan belt to put on a generator belt. The fan pulley has a flange on one side that screws in and out and tightens the fan belt by making the the belt run further out on the pulley. As for the tractor quitting after a few seconds, 2 things I would start with is make sure you have spark and a good continuous flow of gas. A partially plugged line, screen, etc will let you get started, but not enough flow to keep going. Old tractors can have a number of issues with corrosion in tanks and fuel lines.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
