Probably an adjustment. First off, I assume the carburetor is functioning OK and properly adjusted (idle is good and engine seems to develop good power at high speed). If so, the next thing to check is the adjustment of the linkage between the governor and the carburetor. The linkage has a threaded end at the front. No magic to this, just do it by the book. If this doesn't cure it, you need to adjust the bumper spring on the governor. There should be an acorn nut on the bottom of the governor housing. Remove it to expose a threaded stud with a jam nut. The bumper spring is on the end of the stud. Loosen the lock nut and turn the stud in a little and test the results. Repeat if needed. Only turn the stud in enough to eliminate the surging. Tighten the jam nut and put the acorn nut back on.
If you have not had the governor apart, you should remove the stud completely and check/clean the spring (the spring will come out with it). Sometimes the springs are gummed up, rusty or even broken.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
