Re: Farmall B 12v generator conversion
Posted by Bob M on March 30, 2010 at 20:04:14 from (74.67.187.148):
In Reply to: Farmall B 12v generator conversion posted by Seth Boyer on March 30, 2010 at 19:40:32:
Seth - I highly recommend you use a regulator instead of a cutout on your conversion (your battery will thank you later!) You can get a saddle-mount regulator that fits on the generator case in place of the current cutout.
You can re-use the existing 4-position light switch. Only difference is with a voltage regulator installed the switch's L and H positions simply become two "off" positions for the lights.
I forget the 12 "correct" volt bulb number for the teardrop lights. But the common 1156 backup/turn signal bulb fits and works fine.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
