Posted by Wild Bill Caldwell on April 01, 2010 at 19:53:50 from (74.249.145.108):
Been a while since I posted on here....recently picked up a 1949 Cub , needed points , dist. cap had #1 plug wire startin" in the wrong hole , I,ve never had a problem timein" any engine but this one is beatin" Me....With an overhead valve engine I line up the timein" marks on the crankshaft pully , pull a valve cover to be sure the rocker arms are loose and go from there. As Yaw"ll know the Cub don"t have overhead valves , I pulled the side cover thinkin" the lifters would be loose when # 1 is up and ready to fire but I haven"t found a place yet where both are loose when the crankshaft lines up with the marker so I guess the valves need adjustin"....that idea ain"t workin....Tried lookin" in the spark plug hole to see if the valves are shut , can"t really tell....So I"m tryin" to get around pullin" the timein" gear cover , is there an easier way to get things straightened out....I"d know for sure if I could see the crank gear and cam gear markin"s...I"ve tried (several times ) holdin" My thumb over the #1 spark plug hole but I"m sure missin" out somewhere....anybody got any ideas ? Thanks Wild Bill
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
