If you are unsure of the tractor"s history, you"d best measure the bore of the sleeve, the bore of the block with sleeve removed, and the piston diameter. Who knows what a previous owner could have modified or goofed up already? Putting H sleeves into a block modified for Super H parts would be catastrophic if assembled and ran. When measuring, you may find the wrong combination of parts in there if someone was really sloppy in their work or plain stupid. by the way, you never replace just the sleeves or pistons--they are a package deal. Not that it hasn"t been done or a rare situation might warrant one and not the other. Usually a worn engine is renewed with piston and sleeve assemblies. Sometimes a new set of rings is installed in the old piston and sleeve. But usually when these engines are torn down, they need new everything because of the wear or damage.
When you have it apart, fix it right so you never have to have it apart til it"s worn out and old again. Again, measure everything if you aren"t sure. Measure if you think you are :)
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
