Since you know something is sticking within the clutch, maybe a lot is sticking. Makes me think Bob is on the right track. If it won't come apart following the suggestions already made, you may need to unbolt the pressure plate from the flywheel. I've never had to try it, but think you can do it through the hand hole in the bell housing. If the pressure plate is the type where 3 bolts are used to hold the springs compressed, move every other pressure plate bolt to the open holes then remove the 3 remaining bolts. If you can do that, the pressure plate and clutch disk will stay in the bell housing when you split it. Then you can get at the disk to remove it from the splined shaft.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
