Posted by Tom Fleming on April 03, 2010 at 19:12:24 from (67.20.229.132):
In Reply to: f-20 Magneto Troubles posted by Ryan Lander on April 03, 2010 at 10:12:19:
This doesn't make sense. The faster you turn a mag, the hotter the spark. That is why there is an impulse so that you can get a hotter spark at hand cranking speeds. the impulse spins the mag faster under spring tension.
I am not challenging your statements, but this really just doesn't add up. If the spark is hot at impulse RPM's, it should stay hot, and get even hotter at higher RPM's, ie. running.
I need to noodle on this a bit. Although it could be the coil has a partial short in it, and it doesn't ground out until you are getting the higher voltage from the higher RPM's. the condenser may be playing a part here to. I have just never heard of this behavior before.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
