If run more than 120% there might be issues with its life span. a 1:3 ratio would be fine. The setup to use a pump on the front is good. The biggest difficulty is in either positioning the pump to clear the frame rails on either side, hanging it down under, or making a reliable constant velocity joint to use the hand crank shaft hole. I would use a surplus hydro pump designed to run at 2000 or more RPM, and a cog belt drive in front of the front pulley. I would also probably use an electric thermostatically controlled fan to allow more room in that area. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
