Re: Farmall B 12v conversion questions???
Posted by Red Dave on April 04, 2010 at 16:39:51 from (174.59.227.184):
In Reply to: Farmall B 12v conversion questions??? posted by Seth Boyer on April 04, 2010 at 16:05:46:
Yes, changing to a 12 volt regulator will make it put out 12 volts. But it will not put out any more total energy (wattage).
If your maximum generator output at 6 volts was 20 amps (just to pick a number), it will be half that, or 10 amps at 12 volts. Double the volts at half the amps equals the same watts as original.
It will do 12 volts, but it can never put out nearly as much power as even a small 12 volt alternator.
But, if it still has a magneto, and all you need is to charge the battery for starting, it may well be enough for your needs.
Whether that is acceptable or not is up to you.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
