Posted by Kevin Brooks on April 05, 2010 at 12:33:37 from (129.42.208.179):
Have an "51 M with partially rebuilt carb: new needle/seat cage and gasket, new float bowl gasket. Float level measured 1 5/16" per manual. Finding gas leaking out choke lever shaft after increasing engine speed control. What is likely causing the leak. Also, main fuel/air mixture screw currently set at 3 turns out. Not yet tuned for full throttle. Would leak disappear once tuned? Tractor head listed as 6336 for kerosene and carburetor has numbers matching those for kerosene. However, I only run gas.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
