Farmall Radiators
Posted by GordoSD on April 05, 2010 at 17:35:44 from (216.106.250.66):
After removing, instaliing, removing installing a couple of radiators on my SH tractors I have a couple tips for you all.
One Use new hardware everywhere. I did this and when one rad had a leak I was able take it off in about 10 minutes.
Two. Those impossible castle nuts and cotter keys. Sure, you can't use a standard nut and lock washer because you are only compressing the washer against a spring. Solution? 7/16 fine nylon insert locknut.
Three. Cut your pads in rectangular shape from old conveyor or similar belt material on the band saw. You can cut a dozen the right size in a minute. Anyone need any? I got to cutting them and couldn't stop. Three bucks for a pair and no postage. Farmall guys only. Email open.
Gordo
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
