Posted by Dan Swanson on April 06, 2010 at 04:46:07 from (63.172.252.199):
Looking at possibly buying a 756 with TA and 310D. Ran it last night. Engine runs great. With the T/A back, when you let out the clutch it really slips before it gets moving but the clutch pedal hits the floor of the cab. When you step on the brakes with the clutch out it stops real easy and the motor doesn't really pull down much. When you start out with the T/A forward, it starts out immediately and when you step on the brakes you can kill the tractor in 2H pretty easy. The power steering seems to be O.K. and the loader is ran off a remote hyd. with a power beyond valve. It seems to work o.k. too. You can lift the front of the tractor off the ground at an idle. Am I close at thinking maybe all is needed is to adjust the clutch and T/A per manual to get it to properly engage with the T/A back? Or it there something much deeper? What is the correct procedjure for starting it with the throttle cable and the overfueling setup? Thanks Dan
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
