The shaft the gear is on is actually a long shaft that goes way to the front of the ta housing. You can remove pto rear unit and get the coupler off, butttttt, with out looking in manual, I don't think there is enough room to pull gear off due to interference with other components. And, the shaft will also be worn. This was a definite problem with the closed center hydraulic pump when using the pto any amount. A gear pump conversion will be much more tolerant of looseness within reason of course. It is a major job to repair correctly.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
