Diagram #2 is identical to the components on a 12v generator based system. Including voltage regulator and lights. If yours has an alternator, with negative ground, or a generator with Negative ground, the + and minus signs just change. With an alternator (Delco 10SI or equal 3 wire) the diagram for that charging system is included (Its diagram is #5 They are essentially the same on any farmall letter or X00 series. if yours has a relay (solenoid) start (push button start) it will have that circuit going from Amp gauge load side to the push button then to the starter relay S terminal. Best of luck Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
