Posted by Gary Hutchinson on April 08, 2010 at 10:23:52 from (192.236.23.13):
Hey all. Had a slow fluid leak from a fitting on an add-on hydraulic valve mounted to my F560 that is plumbed to the fast hitch. I removed a couple hoses to get clearance to spin the leaking elbow out (so loose I could remove without a wrench). I cleaned it and used some pipe dope on the threads. When I screwed it back in, it was starting to snug up but not tight enough in the rotation I need to run the hoses correctly so I had to go around again and it was pretty tight when I got to the proper rotation. I hooked the hoses back up and fired the rig up. Raising the hitch is normal. Lowering the hitch is slow and labored as if fighting against a load. If I shove the lever all the way forward (down) there is a detent for a "float" function. The hitch actually raises slightly. I'm thinking that screwing in the fitting tight damaged the valve (probably Chinese) and the check valve on the piston side of the clyinder is binding and not letting it empty out properly when filling the ram side. Sound possible? Other ideas?
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
