With a live hyd pump on already on your tractor I would use it. Only extra thing you will need would be a priority flow control valve in the pressure line so that the power steering would have priority of hyds. Otherwise you would loose your ps when using the hyds which coulkd be rather awkward if you were turning or such. If you don't use your hyds then you could get by without the pfc valve. I have a Satge II SM settuo that way as only thing the tractor is used for is to run an auger occasionally. Also have a SMTA that has the ps using the pfc valve so we can use rear hyd remotes if needed.
You can eliminate the pfc valve by using a seperate pump but you're going to have to figure our how to drive the pump off the fan pulley (there's special pulleys that are available, plus you going to have to add a hy reservoir tank for the seperate pump. IMO, there would actually be more plumbing & work involved with ading the 2nd pump than using your tractor's existing live pump.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
