Well, for starters, if your hitch is dropping and correcting itself that means it is leaking. You have a check valve under seat to hold cyl up so either that is leaking or the cyl is. With engine shut off and a load on hitch , remove hose that is not holding load up, if hitch is going down oil will flow out of hose if cyl is problem ,if no oil is coming out of hose and hitch is going down check valve is leaking. After you correct hitch problem then you can see if you still have lifting problems and heating.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
