Posted by pete 23 on April 13, 2010 at 10:11:44 from (173.87.145.42):
In Reply to: Confirmation posted by Kevin in MI on April 13, 2010 at 07:31:59:
You have to realize that the inside end of the bull pinion shaft is supported by the side gear in the differential. These old diff's get pretty worn and allow that gear to move up and down quite a lot. Grabbing ahold of the end of the bull pinion shaft you may very well be feeling that gear moving up and down. You will have to look closely at the bearing to determine if the play is in the bearing itself or the diff. This is common setup on all these style tractors until later larger models like 706 went to a straddle mounted bull pinion with tapered roller bearings on each side of gear. The 656 used a needle bearing or bushing inside the differential to support that end of shaft and tapered roller bearing on the outer end.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
