Posted by Janicholson on April 13, 2010 at 17:40:14 from (64.61.211.227):
In Reply to: Super MD-Hydraulics posted by M.Hamrick on April 13, 2010 at 06:44:54:
The Live Pump Andrew discusses, is located behind the front cover, and in front of the distributor. A Liftall Belly Pump is internal behind the clutch. With a live pump, We would need a picture to see what has been put on it. With a Belly Pump, the fittings on the housing of the tractor (Elbows usually) are all pressure lift, and return combination. The system is intended to use one way cylinders. Lift with spring or gravity return. the right rear port is a delay action port for use with equipment intended to lower after the front, or raise after the front (usually cultivation equipment to finish and start rows fully) Both left and right front ports are hooked together inside and operate like they have a "T" in them going to the pump. So single hoses are used and oil returns through those hoses. It will make about 6 GPM at about 800psi if it is in good shape. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
