Re: 300U shifting problem(all to the rear)
Posted by Janicholson on April 19, 2010 at 07:13:42 from (199.17.6.222):
In Reply to: Re: 300U shifting problem(all to the rear) posted by BMD on April 19, 2010 at 06:40:23:
enerally they wear shch that the tip comes out of the rail befor the rail gets in neutral.then it allows two gears at once. If your tip is looked at you will see where the most wear is located. The H tip should be good to use. The method is to weld up the tip a small amount, and grind it to be just small enough to work well (bigger than worn, and smaller than sticking in the grooves. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
