Hi Ben, the B414 remote outlet that can be controlled by 3pt lever is only single action and a loader bucket requires a double acting cylinder. The proper way to hook up a loader on a B414 is to buy a set of hydraulic control valves, mount then on the loader frame by the right side of the steering wheel. Cut a section out of the high pressure line from the hydraulic pump and connect this line to inlet of hydraulic control valves, connected outlet of hydraulic control valves to remaining section of the high pressure line that goes to the hydraulic reservoir under the seat. If the hydraulic control valves have a low pressure dump line connect this line into the hydraulic filler plug behind the seat.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
