Re: 450 and plow
Posted by mkirsch on April 20, 2010 at 04:44:17 from (64.80.108.57):
In Reply to: 450 and plow posted by Chris450 on April 19, 2010 at 19:19:54:
On a lot of plows you can remove the rear bottom and move any tail wheel that there might be up to the next bottom, to reduce the load.
You might not be able to do this on a 412 plow because it's a Fast Hitch plow and it may throw the line of draft off. That is, the load from the plow will pull off to one side of the tractor, making it impossible to keep straight.
Try it first, anyway. If you're only plowing a small area and the ground is decent you can live with going a little slower.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
