Re: Bull Pinion removal
Posted by Owen Aaland on April 21, 2010 at 10:45:44 from (65.165.246.74):
In Reply to: Bull Pinion removal posted by tambrosi on April 21, 2010 at 04:37:04:
Kevin in MI said: (quoted from post at 11:35:57 04/21/10) So I do have to take the axle housing off to pull the axle, or just the outter axle bearing?
You can do it either way. If you remove the housing the axle just has to slid out of the bull gear. If you remove the outer axle bearing cap you need to push the axle out of the bull gear, the inner axle bearing and slid the outer bearing out of the housing.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
