47H, has the engine been overhauled? The reason I ask, is that if you are replacing a mag with a mag, and the engine hasn't been touched AND it was running before, then the govenor pinion shaft is NOT out of time. Your mag is internally out of time, which is actually pretty easy to correct.
If it is the govenor pinion shaft, you have to take the govenor off the front of the block. there will be timing marks on the cam gear and the govenor pinion gear. it is about a 45 minute job if you take your time.
If the mag is out of time, you have to take the cap and rotor off, and then the internal cover off that holds the rotor shaft on. there are timing marks L or R on the rotor shaft. I believe the J4 mag is CW rotation. If so, then line the rotor shaft up to the R mark with the bevel ground tooth on the mag shaft. Should take all of 15 mins.
I am sure that Gene or I will be happy to talk you through this in either case.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
