Is there any leakage from an axle? A failed inner axle bearing may allow the bull gear and bull pinion gear to slip under load. If that is the problem you should also see the wheel shake as the gears jump teeth. Teeth broken off the ring gear could also cause those symptoms you describe.
With the TA ahead and the transmissions in forth and high range you have eliminated all the transmission gears. The power flow is straight from the clutch disk through the TA high side clutch. Forth gear is coupled to the output quill of the high side clutch and high range has the range transmission main shaft directly coupled to the speed transmission output shaft. Providing you have hydraulics for the brakes that should eliminate the transmissions as the problem.
If you remove the bracket where the upper arm of the three point hitch attaches to the rear frame, you can see the ring gear and the inner axle bearings.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
