Re: loader - farmall compatability
Posted by mkirsch on April 30, 2010 at 08:35:34 from (64.80.108.57):
In Reply to: loader - farmall compatability posted by william chicoine on April 30, 2010 at 07:38:07:
How much cutting and welding are you willing to perform? Any loader can be made to fit any tractor with enough work.
The 606/2606 is a very different layout than the Farmall 706 and 806. So, there is no way it will be a bolt-on affair. Odds are the loader was originally designed to fit many tractors by using different mounting brackets, but odds are also good that you won't be able to find those mounting brackets for your 706 or 806.
That leaves fabricating your own. If you don't have the skills and don't know anyone who does, you're out of luck.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
