Posted by mkirsch on May 01, 2010 at 19:02:27 from (67.253.216.24):
In Reply to: cub mower slips posted by catfixer on May 01, 2010 at 18:10:17:
It's not a slip clutch. It's an overrunning clutch that lets the blades spin when you press the clutch. Without the clutch, the spinning blades would continue to push the Cub forward about 5-10 feet.
The overrunning clutch is shot. You can replace it or you can weld it solid, but be careful if you weld it because of what I said above. Make sure you pop the tractor out of gear each time you press the clutch pedal to prevent the problem.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
