The other replies gave you the practical answer. The technical answer is install an ammeter in the circuit going to the battery and then use a carbon pile load tester to keep the battery voltage low enough so that the voltage regulator will command full output.
The maximum amperage output should match what the regulator is set for. The voltage regulator controls both voltage and maximum amperage. As load is applied to the battery, voltage should remain constant until the maximum amperage is achieved. After that, the amperage should stay constant but the voltage will drop. Anything less than maximum amperage will be controlled but the electrical load and the battery's capacity to accept a charge.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
