Posted by gene bender on May 03, 2010 at 01:30:26 from (207.177.56.155):
In Reply to: farmall 200 governor posted by les holman on May 02, 2010 at 17:11:18:
Chances are when you put it back on the output shaft has enough end play that it got moved side ways enough to make it stuck on one of the two eats that keep it lined up. Put it back on and if it happens again just move the out=-put lever sideways enough to allow it to move. You also mite want to check the pin that keeps that shaft in position itcould be worn and not long enough to allow the shaft to turn. Sometimes you need to drive that pin in a little farther so it can guide the end play better.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
