You're wanting quite a bit of extra power from that engine. To do that, you will need to get more fuel into the engine and you will need to get it burned efficiently. The "extra" parts will help you get there.
The 350 cam gives you a little higher lift and a little longer duration. The LP head has smaller combustion chambers for higher compression. There are tubes cast into the head called "runners" to take the air-fuel mixture to the valves and from there into the cylinder. Cleaning up those runners, and matching the manifold ends to the head ports gets you better air-fuel mixture flow.
With more air-fuel mixture under higher compression you could benefit from a hotter spark. That's how electronic ignition could help.
This project will not really be cheap, which is why a "worker" Farmall M might be a better choice for that generator. It came with the extra ten hp you want built in.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
