Hi Steve, plugged fuel line or fuel filters? When was the last time the fuel filters were changed? Check the crankcase dip stick to see if the level is over full or smells of Diesel fuel. This could be caused by hole in the diaphragm of the fuel lift pump on the right side of the engine. There are bleed screws on the top of the fuel filters and two on the injection pump. Loosen bleed screw on top of first fuel filter closet to fuel tank and pump the hand pump on the right side of the engine until fuel flows without air bubbles. Close this bleed screw and open the bleed screw on top of the secondary fuel filter and repeat process, next repeat with bleed screws on injection pump, starting with the lower bleed screw. If you don't get any fuel flow at the bleed screw the problem is with fuel supply from the fuel tank.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
