The MTA had minimal throw on the main clutch linkage, but it did have a stop bolt on pedal, may check that to see if you can gain a little more movement on clutch pedal. Otherwise, you can reduce the clearance just a little on ta clutch just make sure you maintain some. Maybe just and extra half or full turn on the link from clutch to ta making it a tight pin will do the trick. Ideally, when you push clutch in it should release ta same amount as pulling ta lever but this is sometimes hard to esablish when pedal pivots etc wear. Another thing, the book can be confusing, makes a simple adjustment way too complicated the way they measure things.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
