Re: stuck governor
Posted by ScottyHOMEy on May 06, 2010 at 20:03:49 from (70.105.252.192):
In Reply to: stuck governor posted by rustytenn on May 06, 2010 at 18:48:22:
You're on the right track, rusty. The governor is basically an empty cavty that gets all the lube int needs if the motor is run regularly, but can get crusted up and sticky from lack of use.
The control side, between the lever at the seat up to the fly weights, can be worked loose with the lever, but the other side, that drives the carb, can still be sticky. Start with a good cleaning all over, with special attention to the bushings on the carb side, and replace any parts necessary in the process (like that pesky thrust bearing around the center shaft) and give it a try.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
