ADLM said: (quoted from post at 17:46:08 05/06/10) I was rebuilding the zenith carb on my Farmall A. All was going well, until I broke the venturi. Where do I find a replacement, and how was I supposed to get it out? (venturi no. 15, IH part 62171D)
The venturi is supposed to just lift outm but due to dirt and crud building up around it, they quite often DO become very stuck. Soaking the entire carburetor in GOOD cleaner (not Berrryman's) overnight will usually loosen up that crud. If that doesn't work, you can use a small propane torch to heat the area around the venturi, and then spray that area with penetrating oil while it cools down, and then just walk away from it long enough for it to cool completely, after which you should be able to slowly get it to move by gently trying to turn it with a pair of small channel locks. Those pot metal venturis are very fragile and WILL NOT stand up to any kind of abuse.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
