Re: How to remove shaft from oil filter canister -460
Posted by rustyfarmall on May 08, 2010 at 12:56:41 from (209.152.78.140):
In Reply to: How to remove shaft from oil filter canister -460 posted by F460/200 on May 08, 2010 at 07:02:20:
F460/200 said: (quoted from post at 07:02:20 05/08/10) My canister leaks at the top and I want to replace the brass washer on the shaft. How do you get the shaft out? There is a ring inside which keeps it from coming out and am not sure how to get it off.
The shaft has been over-tightened so many times that the top of the canister is now deformed and most likely has caused a "lip" to form on the inside of the hole. A new brass washer on the shaft will probably NOT fix the leak. You need to find a better canister.
I fought that same kind of leak on my 1940 H. I took the thing all apart one day and discovered what had happened, and went and removed the camister and bolt from a parts H I have. Presto, no more leak. I now have a nicely painted oil filter canister, complete with the "Purolater" decal just sitting on the shelf collecting dust. It is pretty to look at, but no good to use.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
