Re: farmall h engine surges
Posted by Janicholson on May 11, 2010 at 18:07:52 from (199.17.6.222):
In Reply to: Re: farmall h engine surges posted by Drewbee90 on May 11, 2010 at 17:37:01:
Make sure the intake manifold is secure to the head (not easy to see the nuts) They are brass and subject to stripping. Also make sure the carb is attached to the manifold w/o leaks. If it is tight and leak free, the carb may be plugged up internally. There is also the possibility that the intake manifold is cracked between the exhaust ports, and the intake. It is hard to find with the exhaust pipe still on it, but a possible issue. Try the manifold nuts and carb nuts and then try it again. If no better, the carb is next. It could be a failing coil or condenser, but choking it to keep it running popints to fuel. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
