Have you replaced the bearing on the end of the steering wheel shaft? Any play in that bearing and you will have steering play. Also, the bearing must be tightly clamped (inner race) to the steering wheel shaft. And...the outer race has to be clamped in the steering box by the big hex plug on the front of the steering box. Sometimes it's necessary to put a machine washer against the race before installing the big plug to get it tightly clamped in the steering box. It it's not clamped in there, the result is steering play. Slso sometimes the woodruff key that is between the worm wheel and the vertical shaft will get worn and cause play. You said I belive, that you did not take the worm wheel gear out. Was it tight on the shaft and no play between it and the shaft???
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
