Remove the bolts from the front end that bolts to the pan. Remove the bolts in the back of the pan that bolt to the clutch housing. In the back of the pan there are hidden bolts you will have to use and extension to remove them. If i remember there are 4 across the back in the webbing of the pan. I have always used a little floor jack under the pan to let it down easy the pan is a little on the heavy side. When you install the new gasket make sure you also replace the two little black wedges that go at the back of the engine. When you remove the old pan gasket look for them at the back of the engine. Make sure you install them back in with some permatex or you will have a big leak.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
