Posted by Janicholson on May 22, 2010 at 07:14:50 from (64.61.211.204):
In Reply to: super c clutch redo posted by jonathan mirgon on May 22, 2010 at 04:20:49:
Pressure plates are adjusted out of the box! Unless you have good measuring tools, and the solid evidence that things are wrong, leave the screws alone. Your new friction disc could be put in backwards, it must have the cushion springs in the middle facing away from the flywheel. If they are forward, the springs and hub interfere with the bolts on the FW. and the clutch fingers are too far depressed and it will not adjust. A bent friction disk (from even modest force being used to put the tractor back together can also cause drag. A improper Throwout bearing is also a suspect. If the fingers are depressed more than about flat to the disk, I suspect the plate is in backwards. Best of luck. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
